battery light on
Old Feb 22, 2011 | 08:10 PM
Dannyboi40's Avatar
Default battery light on
just installed a brand new battery, and a brand new alt... yet the battery light remains on... where should i go next??? ~Thanks!
Old Feb 22, 2011 | 11:12 PM
What vehicle is this on. I see that you have 3 listed in your garage.
Old Feb 23, 2011 | 06:07 AM
Dannyboi40's Avatar
90 accord lx...
Old Feb 23, 2011 | 03:00 PM
Dannyboi40's Avatar
90 accord lx battery light on whenever I drive anywhere...
Brand new alt... brand new battery... old alt was tested and was bad according to autozone...
Fuses all good... brand new battery terminals...
What else would keep this light on?
Old Feb 23, 2011 | 03:11 PM
Have the new battery/alternator tested at autozone. You want to rule out a bad part out of the box.
Old Feb 23, 2011 | 08:19 PM
And you can "kind of" test it youself. What is the voltage "at" the battery while running....I like to see something in the 14.5 range. Then you can check "at" the alt output lug. Of course the belt is tight and not slipping.
EDIT: most places-autozone-can check that/stuff without having to remove everthing and bring it to them-but that does not rule out a slipping belt.
Old Feb 24, 2011 | 11:13 AM
Dannyboi40's Avatar
Belt is tight like a virgin lol... been driving with battery light on for 4 days..160 miles a day commute. All lights are bright and work fine. No summing of any kind. Car starts just as it dis before these issues.
All connections are tight, and clean on new alt.
The new alt came with paperwork, something about the charging system.. saying if it does jot charge the battery check ecu and something else... I lost the paper like a dummy... my ecu is good. What other components are there in the charging system? Battery, alt, and......?
Old Feb 26, 2011 | 01:12 PM
Dannyboi40's Avatar
any ideas?
Old Feb 26, 2011 | 02:38 PM
I would do steps one and two on this page I referenced below. I don't think that you will have the tools to do step 3.
Just copy and paste into your browser.
media.honda.co.uk/car/owner/media/manuals/accordManual/400/16-94.pdf
Old Feb 26, 2011 | 02:40 PM
What is the voltage at the bat when running. What is the voltage at the "main" cable of the alt while the car is running. What are you getting at the WHT/BLU wire on the alt when the car is running. What are you getting at the BLK/YEL wire of the ign switch....can you/did you stop by and have the parts store check it.
EDIT: once again, slow at typing....thanks PA
schaicho24
Jan 1, 2014 09:10 PM
cadams8221218
Jul 15, 2011 07:24 AM
RoKnAzn
Jan 19, 2007 01:56 PM
Brian
Feb 2, 2006 08:04 PM
