Belt rubbing issue
Old Apr 26, 2017 | 03:55 PM
okwriting's Avatar
Exclamation Belt rubbing issue
Some of you helped me with my son's distributor ear issue, so I'm hoping y'all can help with this. Since the steering is tight turning from a dead stop or when moving very slow, we decided to pull/replace the pump and discovered that the belt that goes from the alternator to the timing belt area is rubbing against a plastic area (timing belt cover) down by where the timing belt is located. It's wearing at the plastic and fraying the belt, too. A 'mechanic' switched out his timing belt and water pump and changed the valve cover gasket a few weeks ago (just for piece of mind) and now we're wondering if he is the reason it's rubbing, and, even more important, how to fix it before the timing belt cover is worn through or the belt frays beyond repair - or both.
Old Apr 26, 2017 | 07:28 PM
I've seen this on the 5th gen's (94-97). There is a bolt for the timing belt tensioner that "pokes" thru the cover. Normally there is a washer -rubber - that slips around the head of the bolt that mates with the cover and holds it back.
Over time that washer goes away and there is nothing to hold the cover. Heat and that then starts to distort the cover.
Easy thing to do is get an "e-clip"/"c-clip" from a hardware store that fits the groove in the bolt.....at least that is how "poorman" handles these....better than a new cover and new OE washer...plus usually you can use one hand to push in the cover while you slip the clip on to the head of the bolt and therefore you do not have to remove anything
Old Apr 26, 2017 | 08:17 PM
okwriting's Avatar
Thanks, poorman212, we'll try it. Any special tools or just slip it on the bolt?
Old Apr 28, 2017 | 04:12 PM
okwriting's Avatar
What size bolt is it? I've been searching online and asking at auto parts stores, and no one knows. I want to make sure I get an e-clip that fits. Thanks!
Old Apr 29, 2017 | 09:23 AM
Again the set up on the 4th gen is a bit different than the 5th gen. In this pic, #27 is what I;m thinking is missing.
Old Apr 29, 2017 | 04:28 PM
okwriting's Avatar
Thanks for the reply, and yes, I understand what you're saying. I'm just trying to get an idea of the bolt size so I know what size e-clip to get. It's ok tho. I'm sure I can just find a fastener assortment pack with a clip that'll work. I do appreciate the help. Thanks!
Old Apr 30, 2017 | 06:49 AM
A guess, 10mm. You can go to one of the many "online honda dealers" websites and look up the parts diagrams. Many times the description of the part will have the spec's
Old May 5, 2017 | 09:47 AM
I found that water hose gasket made a perfect replacement for original gasket.
mikek
Aug 6, 2019 07:37 AM
Jak3l
Sep 3, 2015 09:54 AM
nafango2
Sep 29, 2007 04:02 AM
bullet099
Oct 12, 2005 01:39 AM
Gummi_67
May 26, 2005 10:53 PM
