BIG 95 Accord problem
Old Apr 23, 2011 | 04:20 PM
hOnDaAccOrDsohcVteC's Avatar
Default BIG 95 Accord problem
I have a 95 accord lx sohc vtec.,auto. 177000m.
Around summer 2010- RPM and MPH moved randomly while driving (not positive if MPH did) I could not feel it jerk car or affect driving. Then both needles went to zero while I was driving.
OCT-NOV 2010-Car seemed to not be shifting properly, rpms kind of sputter up.
NOV 2010-rpm drop,car shutting off. (usually when it would shut off it was while I was braking or stopped.)
DEC 2010-Car would not shift, would start and run good, just wouldnt move. (I was told it was the Tranny, which I agreed with, so had it rebuilt.) Also, this happened the day after I got my car inspected when I told them to check my transmission.
Since the tranny got rebuilt (that day after) my rpms have still been dropping as Im driving. It doesn't matter how long im driving and i cant find any real patterns. When they do this I usually pull over and sometimes they continue to act up, usually it just shuts off as I brake. Also, the car has shut off on me already while I driving as well.
I have had battery, wire going to alternator, and ground wire to engine block replaced, and alternator is not even 2yrs old and it was just checked a couple weeks ago.
ANY ideas would be great, so far I put out alot cash for nothing.
thanks,
Old Apr 24, 2011 | 07:59 AM
Check for any stored codes. Then check/test the ICM (or sometimes called ignitor). From there I would then check/test the coil.
Do you have a manual to help with the testing procedures? If not look in the DIY ection for someplace you can download one.
bdawn8403
Feb 1, 2008 08:03 PM
blackex19
May 1, 2007 03:26 AM
sssexy70
Apr 24, 2007 03:24 PM
BIGGS01ES
Apr 3, 2007 10:06 PM
kramrkixass@yahoo.co
Nov 26, 2005 12:42 PM
