bleeding air from cooling sysytem
Old Feb 5, 2009 | 10:12 AM
jackfast's Avatar
Default bleeding air from cooling sysytem
first, i feel like this is a stupid question, so i apologize...
is bleeding done with engine off?
Old Feb 5, 2009 | 11:07 AM
Have you found the bleeder screw in the thermostat housing?
It can be done with engine on or off. I've had better luck with it off, but YMMV.
On the 98 4-cyl Accord I used to have, bubbles would hang out in the high spots of both radiator hoses.
Upper hose bubbles can be pushed into the radiator.
Lower hose bubbles can be pushed into the thermostat housing.
Old Feb 5, 2009 | 12:43 PM
jackfast's Avatar
so just open the valve keep adding fluid until fluid comes out valve?
Old Feb 5, 2009 | 12:54 PM
Yeah, then after you drive the car for a day or 2, check it again. Couple random air bubbles usually make their way to either the thermostat or to the radiator cap.
I usually squeeze the radiator hoses when the engine is cold. You don't want to hear any sloshing, only the little pin rattling in the thermostat.
Old Feb 5, 2009 | 02:02 PM
jackfast's Avatar
got it!
thank you!
something thats bothering me; everytime i check the radiator, i have to add fluid, though there are no visible leaks.
no water in the oil thankfully, but where is this fluid going?
Old Feb 5, 2009 | 04:29 PM
A little bit going out the exhaust (bad headgasket) will not make much noticable steam.
Or...
Get/borrow/rent a cooling system tester. It's a funny little tire-pump thing that attaches where the radiator cap goes. Pressurize the system COLD to find leaks.
Normally, the system pressurizes itself by its temperature. When the fluid leaks out HOT, it can evaporate almost immediately & you have a difficult time finding it.
deserthonda
Mar 30, 2013 01:11 AM
Hondalover
Apr 4, 2011 04:31 PM
Anse
Jun 6, 2009 05:09 PM
silverstreak89
Aug 17, 2006 11:30 AM
LinX
Feb 27, 2006 04:01 AM
