Body repair work advice Cutting a square hole and what is this part called?
Old Sep 18, 2010 | 07:35 PM
ChicagoBob123's Avatar
Default Body repair work advice Cutting a square hole and what is this part called?
Hi I have finally got to working on this Accord. So first stage is the body work.. I am trying to fix up the rear of this 93 Accord hide the rust until it gets worse. The wheel well is not badly rusted but I removed the bumper cover and found it was rusted out worse than I thought.
So I got some galvanized sheet metal and cut and grinded away as much of the rust as possible. I am going to treat the rest with some rust remover.
So I went to look at the passenger side and found this piece was not there.
I don't know what its called and I don't even know if I should bother to look
for a replacement.
One more note.. Does ANYONE know how to cut
a square hole? The things you push in that holds the screws are sadly
square..
Old Sep 18, 2010 | 09:36 PM
kris_loehr's Avatar
I am guessing that part is what is left of mud flaps
BillsWagon
Oct 26, 2011 12:06 PM
letsmakedonuts
Jun 22, 2011 01:05 AM
Boo65
Nov 18, 2010 10:10 AM
lordsusanoo
Aug 20, 2010 09:54 AM
stevolivin
Apr 14, 2010 01:30 AM
