Brake Lamp Monitor
Old Aug 5, 2006 | 01:51 AM
Default RE: Brake Lamp Monitor
Now here's a Smart , Safe person..no drink no drive I Like That...Good Mind..at least I will feel safer with you on the road...
ORIGINAL: DVan8504
ORIGINAL: lightshow
no it wont harm anything. just be careful if youre gonna get krunked tonight
Thanks, I don't drink and drive though
Old Aug 5, 2006 | 02:30 AM
Tony1M's Avatar
ORIGINAL: DVan8504
Is there more than one bulb on the 3rd brake light (the one inside the car behind the window)? Because it was lit up, but maybe there's more than one bulb. My sub could have rattled something loose back there...been playing music loud lately. :-/
Our car is a 92, and there is only one bulb. I hope yours has two, for your sake. On our car, you open the trunk and the lamp is very conveniently accessable at the inside, top, of the trunk, pretty close to the edge and directly under the light housing. It is very simple to change lamps on our car.
Good luck to you.
When you figure it out, please post what the problem was.
Old Aug 5, 2006 | 02:44 AM
deserthonda's Avatar
if all the brake lamps are on,, do as JIMBLAKE suggested ,, i have seen that happen quite a few times ,, sometimes where the bulb makes contact, gets dirty, corroded ..
Old Aug 5, 2006 | 10:29 AM
DVan8504's Avatar
ORIGINAL: Tony1M
ORIGINAL: DVan8504
Good luck to you.
I will definitely let you guys know what the deal is.
Question: All of the brake lights minus the one in the window are accessible by taking off the plastic pieces attached to the trunk lid, correct?
Old Aug 5, 2006 | 02:20 PM
Chiovnidca's Avatar
ORIGINAL: DVan8504
The outer brake lights are accessed behind the trunk lining.
Old Aug 7, 2006 | 02:31 AM
DVan8504's Avatar
Light was off the next day I got in the car. I checked the brake fluid because the light could have also meant that I was low on that, but it was fine. I guess I just won't worry about it unless it happens again.
Old Aug 7, 2006 | 03:55 AM
  #17
ORIGINAL: DVan8504
if the lite that comes on, is where it shows also that the door is ajar,, being low on fluid has nothing to do with that lite........
if you are low on fluid the brake lamp that will lite up is the same when you pull up on the e-brake .....
Old Aug 7, 2006 | 07:57 AM
  #18
92Inspire's Avatar
im glad you let him know that. some people ask me the same at our shop. no offense to anyone but some people just dont know. it never hurts to ask. there are no stupid questions.
Old Aug 9, 2006 | 11:14 PM
  #19
Ruppe
I've got a 91 accord and the brake lamp out light comes on sporadically also. I replaced all the bulbs to with no luck. There also is a left and right light sensor in the tail light assembly. I tapped on it with the handle of a screwdriver and the light on the dash went out. The sensor is going bad. But I'll stick it out until i have no choice to replace it. Virginia inspection criteria states that all lights inside and outside of the vehicle must operate as designed and no warning lights may be on inside of the car.
Old Aug 12, 2006 | 08:36 PM
  #20
DVan8504's Avatar
ORIGINAL: deserthonda
I only checked because someone suggested it either on this board or the other board. And actually the manual does say that light can indicate a problem with the braking system.
MikeT
Aug 31, 2012 10:59 AM
Uber
Dec 19, 2007 02:34 PM
HondaAccord1996
May 11, 2007 12:14 PM
ArcticHonda
Dec 12, 2006 11:27 PM
98accord98
Sep 8, 2006 01:25 AM
