Brake light
Old Jan 14, 2009 | 01:35 PM
poolman's Avatar
Default Brake light
Any clue to what would make the dash brake light warning come on when all the lights are working properly
2002, EX, V6
Old Jan 14, 2009 | 01:46 PM
finch13's Avatar
Default RE: Brake light
Low brake fluid can cause the light to come on.
Old Jan 14, 2009 | 01:57 PM
poolman's Avatar
That's a different warning light on my car. This warning light says "brake light". I've check all the lights and none of them are out
Old Jan 14, 2009 | 02:07 PM
Sweagle02's Avatar
e-brake might not be all the way to the off position or most likely what finch said, low on brake fluid.
Old Jan 14, 2009 | 02:09 PM
Tippman7641's Avatar
dose the brake light on the back of the little car symbol that shows you what door is open, mean like the acual brake lamp itself is out or low fluid?
Old Jan 14, 2009 | 03:54 PM
There are TWO brake warning lamps. One of them is for the handbrake & low fluid.
Sounds like Poolman is talking about the one thats SUPPOSED to detect burned-out brake light bulbs.
That one is based on comparing wattage among the brake lamps. Sometimes a dirty socket can set it off, loose, corrosion or something like that. Sometimes it can be set off by a bulb growing old & gradually changing its electrical resistance. Sometimes you have to replace ALL the bulbs just so they MATCH each other.
Old Jan 14, 2009 | 05:44 PM
poolman's Avatar
Thanks Jim!! It looks like you put me in the right direction. I took all the bulbs out and cleaned the sockets ( they didn't look bad ) and the light went out.
DannyJdm
Mar 28, 2012 08:03 AM
victorywhity
Mar 24, 2011 09:37 PM
drtysohc
Feb 3, 2008 03:23 PM
98accord98
Sep 8, 2006 01:25 AM
