BRAKE light on dashboard sticks?
Old Sep 28, 2009 | 07:17 PM
mamtsberg's Avatar
Default BRAKE light on dashboard sticks?
2001 Accord, 4 cyl, 5 speed.
The dashboard BRAKE light on my Accord seems to be "sticking". I disengage the parking brake and it says on for a little while and then it will go off. It only seems to happen when it's "colder" out. Brake fluid level is fine.
For example: I work the overnight shift (6pm to 6am), when I leave in the afternoons (when it's warmer), the light might stay on for a minute, if it stays on at all. When I leave work in the early morning (when it's "cooler/colder) the light will usually stay on until I"m almost home (it's a 12 mile commute to the light might go off around 8-10 miles).
I fiddled with the parking brake (just pulling it from the inside) and that did nothing. I have to pass some rumble strips on the way home and a couple times it's gone off right after I went over them, which is why I think it's something "sticking" that sticks more when it's cold and then gets jarred loose after the rumble strips.
I haven't had a chance to get look at anything so far but figured I would get some feedback here first.
Old Sep 28, 2009 | 11:07 PM
deserthonda's Avatar
sounds like the brake master cylinder float sticking ........
buying a new master cap kit should fix it
Old Oct 2, 2009 | 12:05 PM
bigdawg74's Avatar
Desert, do you mean #14? My 02 Accord is having similar problems.
Old Oct 3, 2009 | 02:15 PM
bigdawg74's Avatar
bump...
Old Oct 3, 2009 | 07:02 PM
#14 is correct.
Old Oct 3, 2009 | 08:06 PM
bigdawg74's Avatar
Thank you for the confirmation.
Old Oct 5, 2009 | 09:48 AM
Down inside the fluid reservoir is a mesh screen basket - pull it out. Sometimes that thing gets warped so it drags against the float. In that case, a new cap/float won't fix it. Check that out too.
indy49
Dec 16, 2011 09:13 PM
cory43112
Nov 3, 2007 05:50 PM
19962door
Jun 28, 2007 03:11 PM
gypsyman
Jun 4, 2007 05:39 PM
balance55113
Dec 19, 2006 08:53 PM
