Brake Light Indicator
Hey.
I replaced my front calipers, rotors and pads. I bled the brakes everything seems to be working fine. Now the brake light indicator still comes on. Is there anyway to reset it?
I don't see or feel anything wrong so far with the brakes, all light bulbs seem to be fine unless the parking brake needs adjustment, which I don't know because it still holds the car, I don't know why that light is on. Normally it goes off when you take the parking brake out, but it's not turning off this time.
Any ideas why it still shows or on how to reset it?
Honda Accord 2003 Sedan 2.4 liter 4cyl.
Thanks!
Thanks!
Does your brake master cylinder reservoir or reservoir lid have an electrical connector? I know that through 2002, there was a float built into the reservoir lid that would turn on the e-brake light if the fluid got below a certain level.
Not sure that 03+ accords have that feature.
2003 had some kind of level-sensor in the side of the reservoir, not a float in the cap.
But the "brake lamp" warning is all about burned-out bulbs in the taillight clusters. It works by the wattage of the bulbs, so they need to be the correct wattage.
I'm Not sure either. I have to look!
I guess I will check that.
Hey Jim, thanks for the tip last time, everything you said worked.
Post that back over in the other thread, then anyone who finds that thread by searching will know the end of the story.
victorywhity
Mar 24, 2011 09:37 PM
GjB
Jan 23, 2011 05:51 PM
