Brake Light Switch.
Old Mar 18, 2012 | 12:27 PM
W/ a multimeter you test by measuring either open circuit (leads not touching each) or short circuit (leads touched together). Note the readings when you do this and this will allow you to understand whether you are measuring a short or open when testing the switch.
Old Apr 15, 2012 | 12:23 PM
MizterKewl's Avatar
ok i finally retested it and the switch does have continuity between both 1 and 4...and 2 and 3...So how do I adjust the switch?
Also because it's not adjusted properly is that why it's not showing up on the dash?
Old Apr 15, 2012 | 12:45 PM
The switch is "threadded" with a lock nut.
Old Apr 15, 2012 | 02:16 PM
MizterKewl's Avatar
alright i'll give this a try...it's going to be difficult to get all the way back there...
Old Apr 15, 2012 | 02:45 PM
Sometimes the little rubber grommet rots and falls out. This will cause brake lights to stay on continuously, since switch would extend through the hole where rubber grommet should be. It's in the picture Poorman attached as far LH element.
rudeg
Dec 31, 2015 07:23 PM
Rabbit
Sep 14, 2012 02:27 PM
victorywhity
Mar 24, 2011 09:37 PM
jdelgado
Oct 29, 2007 09:49 PM
greaser
Aug 24, 2005 12:01 AM
