brakes
Old Mar 14, 2012 | 11:35 AM
rizzo1234's Avatar
Default brakes
I just bought a 95 accord ex/v6 2.7L, the abs motor is always running, until I pull the E-brake,,, I'm lost,, because the brake work fine
Old Mar 14, 2012 | 06:42 PM
Are you getting any codes?
Have you check the brake fluid in the master cyl and the ABS unit?
Old Mar 16, 2012 | 12:08 AM
rizzo1234's Avatar
Yes, I reversed bled it from the brake caliper up, but the abs motor runs constantly, until I pull the E-brake
95 Honda EX a/t V6
Old Mar 16, 2012 | 12:09 AM
rizzo1234's Avatar
don't C any codes either..
95 Honda EX a/t V6
Old Mar 16, 2012 | 07:12 PM
I would bleed the abs unit as well. In the "Common DIY Threads" sticky at the top of this section there is a "how to"...or here
https://www.hondaaccordforum.com/for...systems-31259/
While doing this, look for signs of leaks around the unit. There is an o-ring that fails sometimes.
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
