brakes going to the floor
Old Jun 23, 2007 | 03:44 PM
90 accord lx's Avatar
Default brakes going to the floor
1990 accord,been sitting for about a year,my son and I have been slowly fixing it for him to drive.Now that we're ready to drive it,we keep losing the brakes.They work sometimes,then they go to the floor.I would appreciate any input.Pads and shoes are like new,no fluid appears to be leaking,could it possably be mastercylinder?HELP
Old Jun 23, 2007 | 05:22 PM
tkundert2's Avatar
Default RE: brakes going to the floor
At that age, many things could be suspect. I would inspect all the hoses and replace the fluid and bleed as a first step. The MC and brake cylinders could be in bad shape as well.
Old Jun 23, 2007 | 06:51 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Jun 23, 2007 | 09:22 PM
The classic difference between air in the lines vs. a bad brake master cylinder goes like this...
Air causes the pedal to go soft when you first apply the brakes. Pump them & the pedal becomes hard.
With a bad master cylinder the brake pedal is initially solid. Then it slowly & smoothly sinks to the floor. It seems worse on really hot days.
Old Jun 24, 2007 | 10:25 AM
Chiovnidca's Avatar
ORIGINAL: 90 accord lx
Sounds like a bad master cylinder to me.
Old Jun 24, 2007 | 09:34 PM
peewee's Avatar
Agreed. I just did a master on an explorer with very similar problems. Dont forget to bench bleed the new one, even though I did!
Old Jun 27, 2007 | 09:26 PM
mastercylinder fixed it,thanks
barbakos
Aug 10, 2011 02:33 PM
jennycampbell
Dec 16, 2010 08:45 AM
markinchico43
Jan 20, 2008 08:34 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
