Broken hood latch lever
Old Oct 15, 2007 | 01:09 AM
Planefreak's Avatar
Default Broken hood latch lever
My Accord, is kind of old, but it works. The lever to pop the hood however is not working right. It takes a ton of force to open and it has already broken off the top plastic mount. The bottom is starting to show stress fractures and I need to do something. I tried wd 40 on it just to see if it would help, but no luck. What do you guys think?
Old Oct 15, 2007 | 08:37 AM
nafango2's Avatar
Default RE: Broken hood latch lever
take it off and install some hood pins?
my friends dad did that on an old mazda 323 he had.
Old Oct 15, 2007 | 09:01 AM
falkore24's Avatar
take the latch portion off that holds the hood closed and clean it with parts cleaner to loosen it up.
Old Oct 15, 2007 | 12:17 PM
There was a post recently on another forum about a small rubber or plastic plug that could be removed from the latch plate that allowed access to release the latch w/ a screw driver through the grill. You might want to look carefully at the latch and in necessary determine where a hole needs to be to allow access to release from grill entry.
bjr001
Feb 7, 2021 11:19 AM
bmarz
Aug 15, 2013 06:52 AM
RedLineZ_05
Oct 18, 2012 09:24 PM
navyned
Jan 24, 2012 07:32 AM
rockchalkseahawk
Oct 4, 2006 01:10 PM
