Broken Timing Belt
Old Oct 24, 2020 | 08:22 PM
  #21
mrg2065's Avatar
Originally Posted by mrg2065
?????? Ugh, head is together, camshaft fastened down in tdc, rocker arm assembly torqued to specifications. both #2 exhaust slightly open, #4 intakes open, going by memory, is that how tdc is on head. Those valves mentioned, lash adjusters fully loosened, have no rocker arm movement.
thanks,
my mistake #3 intake and #2 exhaust, was worried till I seen what #1 piston @ :tdc looked like. Bolting head down now,.
Old Nov 18, 2020 | 02:22 PM
  #22
mrg2065's Avatar
Together, fired it up, idle wouldn't die down after engine warmed. Cel on, 6 short flashes, coolant thing, would it be the iacv(sp), one got the plug going in, or the fitv..., update been adjusting the fitv, no change, so pull other and check. Vid of cold engine start up. Started it other day, valve cover gasket didn't set in back, lost oil, thought I could re-use the 2 month old gasket. No exhaust hooked up yet.
59coop
Sep 5, 2017 07:22 PM
Hicksvilleshick
Jul 12, 2015 05:20 PM
KingReset
Oct 20, 2014 06:37 PM
insadj05
Apr 2, 2008 10:28 AM
honda help
Apr 25, 2007 08:34 PM
