A/C Belt Squeal
I just replaced all my belts and the a/c alternator belt squeals at turn on. Just how much deflection should the belt have? It did the same thing before especially when the a/c is turned on. After warmup the squeal goes away.
Thanks for all the help guys! The tension was way toolow causing the belt to slip. I just followed the original belt tension as a guide but it was apparently way too low. At a 1/4" the tension is pretty firm, but no more squealing.
ORIGINAL: YeuEmMaiMai
did you get any grease on the belt? if so use some belt dressing to clean it up
