Sponsored by:
Sponsored by:
A/C Belt Squeal
Old 12-30-2006, 11:16 PM
91boz's Avatar
Default A/C Belt Squeal
I just replaced all my belts and the a/c alternator belt squeals at turn on. Just how much deflection should the belt have? It did the same thing before especially when the a/c is turned on. After warmup the squeal goes away.
Old 12-30-2006, 11:29 PM
drummer1279's Avatar
Default RE: A/C Belt Squeal
1/4 inch deflection at the most. try to get it slightly less.
Old 12-31-2006, 04:06 AM
hondadude's Avatar
yeah I agree1/4 inch deflection MAXas you push on the longest span, we're talking banjo string tight for that belt.
Old 12-31-2006, 08:44 AM
YeuEmMaiMai's Avatar
did you get any grease on the belt? if so use some belt dressing to clean it up
Old 12-31-2006, 04:43 PM
91boz's Avatar
Thanks for all the help guys! The tension was way toolow causing the belt to slip. I just followed the original belt tension as a guide but it was apparently way too low. At a 1/4" the tension is pretty firm, but no more squealing.
Old 01-01-2007, 12:39 AM
hondadude's Avatar
ORIGINAL: YeuEmMaiMai
the squeal noise is caused by friction between the pulley and the belt, most people can understand that grease and oil are commonly used to reduce friction.
dondrup
01-21-2013 10:49 PM
Cinci90
01-19-2009 08:08 PM
TexasHonda
08-23-2008 03:30 PM
will93
03-17-2008 07:21 PM
ckebottle
09-23-2006 09:35 PM
Quick Reply: A/C Belt Squeal
