A/C Blowing hot at idle
Old Aug 13, 2011 | 06:39 AM
mtaka's Avatar
Default A/C Blowing hot at idle
Here is the issue.
I live in Florida
When it is hot outside, the A/C blows warm when I am at idle or in Park, but it blows cold when I start driving.
I checked the both fans, and they are working. In addition, the the condenser and dryer are new because because I had a leak.
So, I did a test by putting the car in Park, and I start accelerating the car. The A/C started blowing cold, so now I am at loss.
Old Aug 13, 2011 | 09:51 AM
hobieslug45's Avatar
your going to need a set of gauges to check if your compressor is weak
Old Aug 13, 2011 | 09:54 AM
also was the system evacuated properly when you changed the condenser.
Old Aug 13, 2011 | 10:04 AM
Is the compressor engaged at idle? It may be dropping out. If it's engaged, then fault could be weak compressor, low charge, expansion valve, dirty condensor face (restricting idle air flow).
Old Aug 13, 2011 | 10:19 AM
mtaka's Avatar
The condenser and dryer were changed by an auto repair shop. It was changed in May 2011.
Old Aug 14, 2011 | 08:34 AM
you need a set of gauges to figure out all the scenarios that texashonda wrote
BHoward711
Apr 12, 2010 08:57 PM
dsgammo
Nov 12, 2008 07:59 AM
roseyn1234
Jun 24, 2008 11:51 AM
soldierforchrist2
Dec 4, 2005 11:34 PM
jordan
Sep 6, 2005 11:35 PM
