a/c blows cool not cold
Old Sep 28, 2009 | 06:40 PM
jimshady's Avatar
Default a/c blows cool not cold
a/c only blows 59 deg good system pressure 30 low side 220 high side.both fans work and i blocked off the heater hose.96 accord 2.2 dx with 204,000 miles.does the honda system use an orfice tube or expansion valve.
Old Sep 28, 2009 | 11:08 PM
deserthonda's Avatar
exp valve located in the evap case ..
Old Sep 29, 2009 | 08:26 PM
hondadude's Avatar
Measure vent temp with blower on low/ control set to Recirc.
Also to see the max cool temp, use a spray bottle to squirt some water on the condensor.
You might want to try some detergent and garden hose to clean out the condensor and radiator fins. NOT HIGH PRESSURE HOSE.
Old Sep 30, 2009 | 02:46 PM
jimshady's Avatar
59 deg is on low. the condensor looks good and i allready washed it out high side pressure is only 220 to 250 at 2000 rpm so i dont think its a condensor problem.
drfence
May 9, 2019 07:53 AM
4x4aholic
Nov 3, 2013 06:26 AM
EXV6NIGHTHAWK
Oct 9, 2010 10:35 PM
spoconn
Aug 21, 2009 07:06 AM
74joe74
Jul 2, 2009 07:26 AM
