A/C Has been fixed...
Old Jul 12, 2012 | 12:20 AM
94ex915's Avatar
Almost A Senior Member
Originally Posted by PAhonda
The rpm is important, because the pressures will change at higher rpm. Then you will be sure if you are over or under charged.
Ya I think he said it might still be a little bit overcharged due to that noise I keep hearing. I am taking to back soon. Or I can just release a little pressure myself
What do you think about the dimming and the low rpms? Should I be concerned or what else could I do to fix this problem. Would adjusting the idle myself be a good/bad idea?
Old Jul 12, 2012 | 12:45 AM
Adjusting the idle would be bad, IMO.
Since this only happens when you turn on the a/c, don't use it. I suspect that your compressor is over-charged, but you really should test the pressures first.
Running the compressor with too much R-134a can cause damage to the compressor and you will have a very expensive repair.
You may want to get a quote from a shop on what they would charge to get the system to the proper level.
Old Jul 12, 2012 | 12:53 AM
94ex915's Avatar
Ahh alright. I wont touch it then. Its not a bad idle drop but I just don't like the way it feels. Dunno... Maybe im to picky.. lol.
Old Jul 12, 2012 | 01:15 AM
94ex915's Avatar
Also... What else can I do to fix the rpms or is this just normal?
Been reading a little bit more and this pressure I hear being released is coming from something called a High Pressure Relief Valve... Ever heard of this?
Edit:
Actually found what it sounds like... Go to 1:54 of the video.
Old Jul 12, 2012 | 08:22 AM
If the AC is venting through it's pressure-relief valve, then maybe the AC system is obstructed (expansion valve?).
Look in the DIY section for a post by me about setting the BASE idle. That procedure is important; you can mess it up by trying to adjust your working idle with the idle-air screw. Even worse, if someone has tried messing with the throttle cable in a misguided attempt to adjust the idle...
Honda's idle-control is finicky. It's important to set it up so the IACV is in the proper spot of it's control range. If not, it might idle OK but it won't handle extra loads like AC.
Old Jul 12, 2012 | 12:05 PM
94ex915's Avatar
Alright I read everything in the DIY. Now I just need to know where the idle air screw is. I cant seem to find it
Old Jul 12, 2012 | 02:07 PM
  #17
It's #1 in this picture. Actually, it's inside a hole above the bore of the throttlebody. Look for a brass screw-head with a slot for a flat-blade screwdriver.
neophyte
Feb 19, 2011 08:30 AM
mig25
May 24, 2007 03:50 PM
LostinMaine
Aug 20, 2006 11:58 AM
