cam chain timing issue
Old Mar 17, 2012 | 11:55 PM
sgman3rd's Avatar
Default cam chain timing issue
Please help!! At end of my wits!! Recently my 2003 Honda accord EX, 2.2L, AT, stalled, every time it started the RPMs would drop to below 1000 and eventually it didn’t start again. Received code to replace crank shaft position sensor. After replacing, every time I cranked the engine, it would misfire and not turn over. I then checked the timing chain and found timing was off. I had to replace the cam chain tensioner because the chain was slipping. It fixed the slipping problem however the car will not turn over. It misfires at time but most of the time it just spins. I have checked the spark plugs and wires, I have spark. The fuel pressure is good, and I have also replaced the camshaft sensor as well. What am I missing?? Every time I check the crank, camshaft intake and camshaft exhaust they align at TDC.
Old Mar 18, 2012 | 09:06 AM
Might want to check the compression of each cyl. If the timing was off, possible the valves got bent.
firedog261
Oct 5, 2013 03:37 PM
Sethgreen
Aug 4, 2011 01:58 PM
ss485
Feb 23, 2011 08:18 PM
olorin
Jan 22, 2007 05:22 PM
