Can I tow a motorcycle trailer with my 1994 Accord A/T?
Old Aug 27, 2013 | 10:57 AM
faran's Avatar
Almost A Senior Member
Default Can I tow a motorcycle trailer with my 1994 Accord A/T?
Hi Guys-
Not sure, if its a weird question, but I am planning to buy a bike.
It's nearly 60 miles away from me. I am planning to get U-Haul motorcycle trailer:
U-Haul
Can I use my old 1994 Honda Accord EX(A/T) to tow a motorcycle which is nearly 541 lbs?
Please advise, any input or feedback about it. Thanks again
Old Aug 27, 2013 | 05:40 PM
Yes, be gentle on it and you will be fine. I don't even want to talk about the things I towed with the 95 EX
Old Aug 28, 2013 | 02:41 AM
UhOh's Avatar
It motorcycle is rideable (vs. needs repairs) it'll be all around simpler in my book
to get a friend with a M/C license to ride it home for you...
Old Aug 28, 2013 | 09:53 PM
faran's Avatar
Motorcycle is derivable but, do I have to have a hitch or can i jut hook the trailer in the rear hook?
My car has a hook thing below the rear bumper, in almost the center. Is it good for towing or no?
Old Aug 28, 2013 | 09:54 PM
faran's Avatar
Does anyone has any motorcycle towing experience? If so, please share and advise. Thanks
Old Aug 28, 2013 | 10:25 PM
wunderbra's Avatar
We just came back from a trip towing my Honda Motorcycle behind our Toyota Avalon. 3200 miles, no problem. It was lighter than yours and on a light trailer. Those U-haul trailers are really heavy. Check around to see if you can rent just a small utility trailer that is lighter. The key is to keep the transmission fluid from getting hot. If it is 90 degrees outside, or higher, that might be a problem on that Honda automatic. Just tie it down well on each handlebar and once through the rear wheel and you should be fine. If it is only 60 miles, should be okay. Just keep the speed below about 60.
Old Aug 29, 2013 | 07:14 AM
That hook thing below the rear bumper is NOT OK for pulling a trailer. That's a tie-down loop for holding the car down while being shipped on a ship or railcar. It won't react properly to the loads while driving, especially in a panic-stop.
Old Aug 29, 2013 | 08:48 AM
faran's Avatar
As always, thanks so much. Then where should I install a Hitch? Do I need to have a hitch to pull the bike trailer?
Old Aug 29, 2013 | 10:17 AM
A proper hitch probably bolts to a couple other hard points, maybe the structure where the bumper's structural beam is attached?
Anyway, I'm sure you need an actual hitch to be legal.
Old Aug 29, 2013 | 06:00 PM
The hitch on my 95 goes to the "back subframe".
Many choices out there. Go to Curt's website and you can get some ideas.....or this: CURT Manufacturing - CURT Trailer Hitch #11203 | CURT Manufacturing
Again just trying to give you ideas. A local u-haul might install one for less.
KD1977
Jan 6, 2012 10:15 AM
Les
Nov 1, 2011 09:02 PM
PAhonda
Jan 26, 2010 08:02 PM
Tony1M
Jun 6, 2008 03:51 PM
cj_trap_shooter
Mar 22, 2007 02:58 PM
