Car idiot needs help
Old Jan 31, 2012 | 02:13 PM
Nate gj9310's Avatar
Default Car idiot needs help
i just bought a 94 accord ex with god knows how many miles and i am having some issues. rod knock? some say. any other ideas/solutions. i know this is very uninforming but im not sure what to ask. im new at this
Old Jan 31, 2012 | 02:41 PM
Jet sitter's Avatar
Pull the plug wire off each cylinder "one at at time." If it is a rod, the noise will go away when the you reach the bad cylinder. FYI, if it doesn't go away, you likely have a main bearing.
Old Jan 31, 2012 | 03:22 PM
it sounds fine until i hit the gas. i have looked at alot of forums and i get alot of different suggestions but i dont want to end up dumping loads on cash on fixing it or swaping the engine. i have been driving it for a thousand miles or so like this. could it be anything else
Old Jan 31, 2012 | 03:57 PM
what is " a main bearing" any guess on cost to fix. as you can tell it didnt go away. is that better or worse?
Old Jan 31, 2012 | 07:09 PM
Jet sitter's Avatar
Main bearing are what hold the crank in position in the crankcase. Rod bearings are the bearings that connect the piston/connecting rod to the crank. If you hear the rap on acceleration, then it is likely one of the main bearings that is damaged. If this is the case, you are looking at pulling the engine, removing the crank, have it mic'd and installing a new bearing, after they clean up the journal (this is where the bearing sits). A machine shop can clean up the journal and you can install an oversize bearing. I'd take the car to someone locally that you can trust. Where are you located, maybe someone here can suggest a mechanic, or even come over a take a look at it.
Old Jan 31, 2012 | 07:15 PM
Jet sitter's Avatar
I missed this post, you have been driving it for a 1000 miles like this? I doubt if it's a main.
Old Jan 31, 2012 | 09:20 PM
thanks i really appreciate the help. yes its been about 1000 miles. back to the drawing board i guess. the sound doesnt seem to be getting worse but i am getting more and more nervous every time i drive it. i just dont know what to do. engine swap maybe but not too much money to work with
Old Feb 1, 2012 | 06:55 PM
Well, I can throw one or two out.
1) Any stored CEL codes?
2) Check the valve lash
3) Pull the heat shield-be careful not to break the bolts- and check for cracks in the exhaust manifold
All of these only cost a bit of time....most of the time the vc gasket can be re-used.
Old Feb 3, 2012 | 06:34 PM
Jet sitter's Avatar
Have you determined what the rap/knock/noise is?
oogie
Dec 12, 2008 12:18 PM
05hondaman
Jan 25, 2008 09:36 AM
suprarx7nut
Jun 21, 2007 12:03 AM
JohnnyWadd
Jan 13, 2007 10:51 PM
ChristopherJ
Jul 31, 2006 01:18 PM
