Car key malfunction - lock/unlock buttons opening the trunk
Old Aug 11, 2023 | 08:29 PM
anonymous's Avatar
Default Car key malfunction - lock/unlock buttons opening the trunk
Hello,
I have a 2014 LX automatic honda accord. Recently the key fob started malfunctioning, when I press the lock or unlock button on the fob the car trunk is opening. Door lock and unlock is no longer working with the key fob.
I have a spare key fob and it behaves the same.
Has anyone ever had this issue with their honda accord and know how to fix it?
Old Aug 13, 2023 | 06:31 PM
Having the same issues on both keys eliminates the keys. Do the door lock/trunk controls inside the car work properly?
Old Aug 13, 2023 | 06:45 PM
anonymous's Avatar
Originally Posted by PAhonda
Have the same issues on both keys eliminates the keys. Do the door lock/trunk controls inside the car work properly?
Yes, the controls inside the car are working as expected. It’s happening only when using the key fob.
Old Aug 13, 2023 | 08:04 PM
The immobilizer on the steering column where you insert the key or have a push button start also has the antenna for the fob. That antenna uses the car's network to send a signal to the MICU to control the door locks/trunk. I'd suspect an issue with the immobilizer/antenna or the wiring based on your description.
You almost need a scanner that can read the signals from the immobilizer/antenna to be 100% sure this is the issue. Or an oscilloscope to see if that unit is sending out a strange digital signal. It is frustrating to troubleshoot modern cars with the specialized tools needed to troubleshoot.
anupm12
Jul 15, 2023 08:18 PM
clayjones
Oct 5, 2022 09:08 AM
JulieG73
Jul 27, 2022 09:11 PM
Weathered
Dec 29, 2018 11:57 PM
reedld3acr
Nov 15, 2008 05:02 AM
