Car not starting after throttle body cleaning
Old Apr 21, 2012 | 03:43 PM
When you turn the key to start the car, does the starter actually spin the engine? Or is the starter spinning the engine, and it is not firing up (when you release the key). Or is nothing happening?
Old Apr 21, 2012 | 04:53 PM
Suggest getting some help, opening the hood, and listen for noises from the starter when key is turned to Start. From your description, the solenoid contacts may not be making contact. They wear out and usually result in a sharp click when solenoid throws, but no starter action.
Old Apr 22, 2012 | 07:02 AM
Never saw the tach move so I can assume the starter is not spinning.
Be sure the cables are clean and tight where they connect to the battery. Do you have a volt meter to take some readings at different places and under some condidtions?
Old Apr 22, 2012 | 11:42 AM
A faulty alarm can cause strange problems with a car.
I would disconnect the battery, and clean all ends of both battery cables using a wire brush.
See if your alarm has some sort of reset on it.
Old May 5, 2012 | 07:47 AM
NemoTeacup's Avatar
Update:
Had to get the starter replaced.
$500 for the part, labor, and the tow.
mclasser
Dec 28, 2013 10:49 PM
kevin1321
Dec 13, 2012 08:32 AM
98accordpain
Oct 17, 2012 07:05 PM
jose310
Feb 3, 2008 04:31 PM
Accord_Ras
Dec 10, 2007 07:19 AM
