Car won’t start, Fuse problems.
Old Sep 27, 2025 | 04:31 PM
MyCaRduDe's Avatar
Default Car won’t start, Fuse problems.
So I have a 2013 Honda Accord LX my car won’t start. Testing the fuses they have continuity, interior fuses 19,20,21,22,23,27 and 41 have a reading of zero volts. Under the hood fuse boxes 23,24 and 25 also have a reading of 0 volts.
when I disconnect the negative terminal it gives me a voltage reading. Need help figuring out what’s going on. Car doesn’t start it makes the click sound but that’s it.
Old Sep 29, 2025 | 05:40 PM
Not all fuses have 12V at all times. The headlight fuses are an example where they only get power when the headlight is on.
Your description of a click from the starter is classic of a starter solenoid problem. You can replace the solenoid or get a new starter. The only other thing could be the + battery cable to the large post on the starter has a bad connection or that large wire is corroded/damaged.
ghoover
Nov 6, 2021 01:36 PM
Crystal Williams
Oct 10, 2013 12:16 PM
Eren_S
Mar 6, 2013 02:37 AM
Hypnos08
Sep 9, 2008 11:19 AM
herzy23
Sep 6, 2006 08:21 PM
