Mystery Electrical Issue-2010 Accord EX-L
Old Oct 5, 2025 | 08:04 PM
rtoliverjr's Avatar
Unhappy Mystery Electrical Issue-2010 Accord EX-L
Hi, please help.
I installed an Android head unit into my 2010 Accord EX-L. Immediately after installation the following stopped working:No interior lights when opening the passenger doors (front/rear); passenger side daytime running light went out; key fob no response; door not locking nor unlocking using driver & passenger door switch; no dashboard illumination; no windshield washer fluid expelling; A/C compressor not turning on.
I used a volt meter and checked all fuses there was continuity in all fuses.
I removed the Android’s Aux cable wiring harness and everything was back to normal - for approximately 1 hour. After I reinstalled the factory head unit and Android device minus the AUX connection - All of the problems previously listed returned.
I then removed the Android device and used the factory head unit only. The problems continue.
Next step was to try disconnecting the battery for approximately 20 minutes to try a hard reset. No luck. Actually they got a bit worse. Now no interior lights when opening any door, the radio doesn’t power up, unable to turn on the headlights unless the engine is turned on.
Thoughts please?
Steisler
Apr 29, 2019 09:11 AM
Sea
Dec 30, 2018 10:15 PM
Brent Paul
Jun 7, 2014 12:23 PM
smartdesserts
Nov 1, 2013 04:00 PM
guinnessmike
Mar 6, 2009 09:16 AM
