Car won't pass emisssions...
Old Feb 11, 2008 | 11:32 AM
isritter
Default Car won't pass emisssions...
Hello,
My wife's car was broken in to and had the entire ignition ripped out. It sat for probably a year before we were able to afford repairs. Now, it won't pass emissions on inspection and we're pretty sure it has something to do with that. Any suggestions on how to clear the CO from the exhaust?
Old Feb 11, 2008 | 12:15 PM
oma93's Avatar
Default RE: Car won't pass emisssions...
Year, model, trim, transmission? Need more info from you.
Old Feb 11, 2008 | 12:24 PM
isritter
94, LX, auto tranny
Old Feb 11, 2008 | 02:10 PM
HondatechAV6's Avatar
i highly doubt emission failure is from ignition switch replacement.
can you post your emission failure specs?
Old Feb 11, 2008 | 02:37 PM
isritter
ORIGINAL: HondatechAV6
No, I'm not suggesting it's from the ignition. I'm suggesting that because it sat undriven for 18 mos., that probably had something to do with it. I don't know if I can find the emissions results but I will search.
I've heard that if a car sits for a long time, that will cause them to fail emissions tests. Is there any way to fix this?
Old Feb 11, 2008 | 02:48 PM
klrspz's Avatar
If you're talking a high buildup of carbon, try some seafoam..
http://www.seafoamsales.com/motorTuneUpConsumer.htm
Old Feb 11, 2008 | 08:18 PM
well, i'd think bad gas can cause a problem(from sitting for so long). i'd start with giving it a few weeks of driving to empty and refill the tank a few times while using a fuel system cleaner.
secondly - can you post your emission failure specS?
Asgaccord
Sep 5, 2013 03:02 PM
1988 Honda Accord
Mar 15, 2012 06:53 AM
biggamejojo
May 24, 2011 11:58 PM
Atheist
Apr 9, 2007 01:15 PM
thunder_x
Nov 6, 2006 08:26 PM
