central locking
Old Jun 5, 2006 | 08:31 PM
andy 95
Default central locking
I have an old 1995 accord , I am having problems with remote central locking . Have replaced batteries in keyring thingy but it is still a bit haphazard. any tips?
Old Jun 6, 2006 | 01:36 AM
lightshow's Avatar
Default RE: central locking
need more info. is it just the remote or do the switches in the car not work too?
Old Jun 6, 2006 | 01:41 AM
deserthonda's Avatar
like Light says we need more info
2 dr 4 dr??
what is it actually doing or not doing ?? not locking ? not opening ? rachety sound ? are you having issues ONLY when you use the remote ??
Old Jun 7, 2006 | 08:30 AM
Sendal's Avatar
Hi, I got the same problem too on my ex accord 98 4 dr
i can't control from remote and main switch on front passanger side power door lock
what do you think ? i need to replace motor or main switch ?
and my another accord 95 sw LX rear passanger power windows doesn't work at all, do i have to replace motor or switch ?
if I have to replace whose part with after market or OEM only ?
thank you....
Old Aug 14, 2007 | 10:54 AM
jseib1946
I am a new member and searched for this answer, but only found questions.
I have a 1995 accord wagon. The remote key has worked, but stopped. I replaced the batteries, and that alone did not fix it. Then I tried a programming sequence I found on line, cycling 4 times of turning key to position 2, pressing the off button, turning the key off. do that 4 times, and the key fob should be programmed. It still does not work. I have doubled checked that the batteries are in correctly, and that they are the correct battery.
ANy thoughts?
Old Aug 14, 2007 | 11:58 AM
On a 94 Accord which may have same remote, the switch connection to the circuit board failed due to fatigue (repeated hard pushes will do the job on these). The switch is tiny and impossible to resolder. A new remote is only solution. Check ebay for used remote keys.
94LXAccord
Oct 3, 2009 01:03 PM
kryat1984
Sep 27, 2009 10:58 AM
HME
Dec 20, 2008 07:00 AM
seasider
Oct 19, 2007 04:40 PM
Data7
Jun 8, 2006 05:31 PM
