Changing out my speed sensor
Old Nov 12, 2011 | 11:39 PM
94LxAccordCoupe's Avatar
Default Changing out my speed sensor
I have a 94 Accord Lx Coupe, 5 speed. How do I identify and remove the old speed sensor? I think it's on the tranny. Can someone give some basic intructions? Thanks in advance!
Old Nov 13, 2011 | 12:03 PM
Are we talking about the VSS? See if the pic helps.....it will be almost right below the TB inlet. Removing the "air duct" will help in seeing it. I think one or two other things need to be moved to get at it, can't remember right now.
Attached Thumbnails Changing out my speed sensor-5th-gen-trans-sensor.jpg   Changing out my speed sensor-5th-gen-speed-sensor-wire-color.jpg
Old Nov 13, 2011 | 01:19 PM
Yes, I'm sorry. Meant the VSS. Is that image you sent where it is located on this model? Cause someone told me that its located on the outside of the tranny.
Old Nov 13, 2011 | 09:55 PM
Yes, it IS on the outside of the trans. That drawing shows it "as if" the distributor and thermostat were invisible & you're looking straight through them. The sensor is down lower & further back along that line-of-sight. It's roughly above the line of the front wheel axles.
That drawing sorta looks like an auto-trans. But the location of the VSS is the same on a manual-trans.
pondrun
Nov 8, 2021 09:40 AM
Afnan
Nov 19, 2013 05:52 PM
94LxAccordCoupe
Nov 12, 2011 11:50 PM
goin to town
Jun 21, 2009 11:04 PM
michaelhayden01
Jun 5, 2005 11:21 AM
