Check engine light with codes P0498 p0420 p0223 p0123
Old Oct 26, 2022 | 07:20 PM
chrrouth's Avatar
Default Check engine light with codes P0498 p0420 p0223 p0123
I was driving home in my 2007 accord 2.4L and a check engine light popped up and it had all the codes, P0498 p0420 p0223 p0123 it’s running fine so it’s nothing major but I didn’t expect to get so many codes all at once. Any ideas on what could be the problem?
Old Oct 26, 2022 | 07:57 PM
P0223 and p0123 deal with the throttle body. P0498 is the evap system that traps gasoline vapors from you gas tank. P0420 is the catalytic converter.
It is strange that all came up when you checked for codes. I'd probably stop by a parts store and have them clear the codes, or clear them yourself if you have a scanner.
If at the parts store, just have them test the battery and alternator, because low voltage in the vehicle can cause strange unrelated things to happen.
Also, have you had any recent work done to the car or any other issues?
Old Oct 26, 2022 | 08:51 PM
chrrouth's Avatar
I just fixed my starter and replaced my battery I’ve been having some electrical issues, my radio and climate controls dim and brighten regularly and my power steering has stopped working for a few turns here and there, usually when it’s raining but I assume that’s just my power steering pump going out oh and I forgot to add I smell fuel/exhaust every once in a while when I drive my car, post the check engine lights
Old Oct 26, 2022 | 10:04 PM
I'd probably disconnect the battery and clean all ends of both battery cables. Also clean the connection at the alternator with the battery disconnected.
When tightening the battery posts, use a 10mm deep socket to tighten down the clamps. I used a 10mm wrench one time and the clamp wasn't tightened enough.
Are the lights still dimming with the new battery?
Old Oct 27, 2022 | 05:09 AM
chrrouth's Avatar
Yes they are I figured I just had some funky wiring somewhere. Do you think that could be effecting those emission codes?
Old Oct 27, 2022 | 02:24 PM
Low voltage can throw off the sensors, so solve the wiring/voltage problem first. Use a volt meter to see what your battery voltage is when engine running, It should be >13.3V.
Old Oct 27, 2022 | 06:25 PM
chrrouth's Avatar
My obd says it’s getting 13.8-14 volts
Old Oct 27, 2022 | 09:43 PM
OBD is probably reading at the ECU, but you could still have a battery cable issue where you have a weak connection to the frame on the negative terminal.
It would be more thorough to put a volt meter on the battery and see if there is a difference.
Big Guy
Nov 4, 2019 07:42 PM
proton8d
Sep 9, 2013 06:05 PM
Rilex
Apr 28, 2013 09:27 AM
arod1970
Jun 2, 2011 10:17 PM
lvt19672
Apr 13, 2007 09:18 PM
