Check Engine in Wi Cold
Hi,
I have a 2002 Honda Accord with 191,000 miles. The check engine and TCS lights just went on in 6 degree weather. Some of the symptoms are: when I put the car in park, the engine will rev between 1k and 2k rpms.
I appreciate any suggestions!
Jay
Jay
It could be many things. Best hope to solve problem is to go to Autozone and have obd2 codes extracted.
TCS light may be a separate issue from Check Engine Light, but sometimes are related.
Be sure to write down the code number Pnnnn and post them here for guidance.
Most likely solution is to clean Idle Air Control Valve, throttle plate, and ports. Sticking valve can cause your symtoms.
See following link to TSB that may be applicable.
http://engine-codes.com/uploads/honda/04-007.pdf
After cleaning reset ECM w/ OBD2 scanner and see if TCM code returns.
Just an update on my issue- the check engine went out about a day after I encountered the problem and the reving went away. I am guessing the problem was primarily due to the cold?!?!
Thanks for the help!
J
J
d0n
Dec 10, 2014 07:42 AM
RyanHostetler
Nov 14, 2013 08:06 PM
mjr.bonez84
Nov 22, 2010 08:49 PM
natew51
Jan 19, 2010 09:16 PM
