Sponsored by:
Sponsored by:
Check Engine in Wi Cold
Old 12-11-2013, 08:26 AM
jayw's Avatar
Default Check Engine in Wi Cold
Hi,
I have a 2002 Honda Accord with 191,000 miles. The check engine and TCS lights just went on in 6 degree weather. Some of the symptoms are: when I put the car in park, the engine will rev between 1k and 2k rpms.
I appreciate any suggestions!
Jay
Old 12-11-2013, 08:58 AM
It could be many things. Best hope to solve problem is to go to Autozone and have obd2 codes extracted.
TCS light may be a separate issue from Check Engine Light, but sometimes are related.
Be sure to write down the code number Pnnnn and post them here for guidance.
Old 12-11-2013, 02:27 PM
jayw's Avatar
Default I got codes- P0505
The autozone code said that it is a P0505 code which apparently is the idle air control. Is this something that is an immediate repair?
Anyone know possible solutions?
Thanks,
J
Old 12-12-2013, 09:39 AM
Most likely solution is to clean Idle Air Control Valve, throttle plate, and ports. Sticking valve can cause your symtoms.
See following link to TSB that may be applicable.
http://engine-codes.com/uploads/honda/04-007.pdf
After cleaning reset ECM w/ OBD2 scanner and see if TCM code returns.
Old 12-14-2013, 10:34 AM
jayw's Avatar
Default Check Engine Light Went Out
Just an update on my issue- the check engine went out about a day after I encountered the problem and the reving went away. I am guessing the problem was primarily due to the cold?!?!
Thanks for the help!
J
d0n
12-10-2014 07:42 AM
RyanHostetler
11-14-2013 08:06 PM
mjr.bonez84
11-22-2010 08:49 PM
natew51
01-19-2010 09:16 PM
spoconn
08-21-2009 07:06 AM
Quick Reply: Check Engine in Wi Cold
