Check Gas Cap Error Message
Old Aug 28, 2009 | 03:32 PM
mcnoople's Avatar
Originally Posted by mcnoople
Have you considered looking in the owners manual?
Clearly stated that when the light comes on it means your vehicle has fail a monitor for p0455 or p0456. If it is 455 (large leak) it can go away quickly. If it is 456 it may take weeks depending on your driving patterns. And yes it does actually require the car to be not running for the code to clear because honda now using something called "engine off natural vacuum" for it's evap leak detection.
As long as your honda says Check Fuel Cap it has not run the 2nd system test. If something is wrong with the car it will turn into a check engine light after running the 2nd test.
Sorry it is just we see this alot and no one ever looks in the manual
BigShelby
Dec 18, 2015 09:36 PM
Lobo1943
Apr 1, 2013 05:45 PM
LS-300
Mar 3, 2012 08:33 AM
SuperGeeky
Jun 26, 2009 05:55 PM
CasualObserver
Dec 14, 2006 02:06 AM
