Chug and stalling
Old Feb 20, 2011 | 04:51 PM
Yeah, I agree fuel pump runs for 2 seconds (when you first turn on the key). That's a preset time and not related to any measured pressure.
Since the fuel pump is running & doesn't stop, that means someone has done some creative wiring.
Old Feb 20, 2011 | 06:07 PM
It's easy to rewire the MFR to allow fuel pump to run full time. I did this on my 94 Accord when I thought I had an intermittent MFR, but instead had an intermittent fuel pump.
Interesting, but probably has nothing to do w/ chugging problem.
Old Feb 23, 2011 | 04:21 PM
FARFRUMNORMAL's Avatar
Default Uggg
Thanks for all the ideas. So the only thing I havent replaced is the timing belt. Can timing be checked ? I guess it is possible the belt jumped a tooth ahead. Doesnt seem to be anyway to turn distributor to see if it runs better.
Old Feb 23, 2011 | 08:24 PM
It's possible to check the spark timing with a timing light, but that won't tell you if the timing belt skipped.
You'll have to remove the plastic upper timing cover and check the marks on the sprocket.
Old Mar 24, 2011 | 02:20 PM
Default Wow
WOW I am really taking this personal. Tonight I will replace the $200 dollar Hitachi coil that I think is ok. I think its the only thing left. Did timing belt,plugs wires cap, map,tps,o2,cleaned egr,checked cat,fuel presure,vac lines and a whole bunch of other stuff. I even had it in a garage for a week and they said sorry dont know..jeesh Gonna have alot of good parts for sale sooon
Old Mar 24, 2011 | 06:27 PM
Most who diy have run into problems that seem to defy logic.
I had a bad ECU recently on my 94ex, a part I thought was virtually bullet proof on Accords. It took a long time to appreciate that when all else has been tested and found good, then what's left must be faulty.
Your only consolation will be when the problem is solved, you will feel a great sense of accomplishment and satisfaction.
Were you able to check timing belt and timing? Kinda confused about sequence of work you've done. Perhaps a chronicle?
Old Mar 25, 2011 | 07:05 AM
  #17
Old Honda Dude's Avatar
Default re-check
Have you tried a propane test? This substitutes fuel to help in diagnostics, such as possible vacum leak. I don't know if there is a section on it in DIY.
Samanthadd
Sep 20, 2013 10:14 AM
92hondaaccordman
Nov 3, 2009 07:16 AM
ramachan9
Oct 16, 2009 09:47 PM
priscilla2237
Aug 1, 2007 01:20 PM
lildragon45
May 6, 2007 10:15 PM
