clockspring help !!! asap
sounds like the cabel reel (clockspring) needs to be centered.
from o.e. :
CABLE REEL ALIGNMENT
from o.e. :
- Misalignment of the cable reel could cause an open in the wiring making the SRS system and the horns inoperative. Center the cable reel whenever the following is performed.
- Installation of the steering wheel
- Installation of the cable reel
- Installation of the steering column
- Other steering-related adjustment or installation
- Do not disassemble the cable reel.
- Do not apply grease on the cable reel.
- If the cable reel shows any signs of damage (for example, it does not rotate smoothly) replace it with a new one.
- If necessary, center the cable reel. (New replacement cable reels come centered.) Do this by first rotating the cable reel clockwise until it stops. Then rotate it counterclockwise (approximately two and a half turns) until the arrow mark on the cable reel label points straight up.
Northernmaine
Feb 21, 2014 05:26 PM
fireblast713
Nov 1, 2010 02:06 AM
Barry92LX
Feb 9, 2010 06:20 PM
firechicken
Feb 2, 2010 03:20 PM
