clockspring help !!! asap
Old Jun 6, 2012 | 01:25 PM
Dr. Drivability's Avatar
sounds like the cabel reel (clockspring) needs to be centered.
from o.e. :
CABLE REEL ALIGNMENT
  • Misalignment of the cable reel could cause an open in the wiring making the SRS system and the horns inoperative. Center the cable reel whenever the following is performed.
  • Installation of the steering wheel
  • Installation of the cable reel
  • Installation of the steering column
  • Other steering-related adjustment or installation
  • Do not disassemble the cable reel.
  • Do not apply grease on the cable reel.
  • If the cable reel shows any signs of damage (for example, it does not rotate smoothly) replace it with a new one.
  1. If necessary, center the cable reel. (New replacement cable reels come centered.) Do this by first rotating the cable reel clockwise until it stops. Then rotate it counterclockwise (approximately two and a half turns) until the arrow mark on the cable reel label points straight up.
Old Jun 7, 2012 | 10:29 AM
jayaccord's Avatar
done fixed it was missing a plug thanks guys all working now
Northernmaine
Feb 21, 2014 05:26 PM
fireblast713
Nov 1, 2010 02:06 AM
firechicken
Feb 2, 2010 03:20 PM
VTach
Oct 29, 2006 09:39 PM
