clutch
Old Dec 17, 2016 | 11:13 AM
h11keu's Avatar
Default clutch
hi .. anybody else ever had this problem.. my 2005 accord ( ctdi ) tourer, twice now the clutch just goes to the floor , very spongey, and imposible to change gear.... i found out the 1st time that if you just put your foot under the clutch pedal, and lift it all the way up it then works perfect... i thought the first time was a one off.... but it just happened again.. same cure.. foot under pedal and lift up... now working fine again.. BUT.. whats causing it.. ?? thanks.. kev
Old Dec 17, 2016 | 11:44 AM
Suspect a failing master cylinder as fault in slave cylinder should not be recoverable. Some replace both slave and master cylinders at same time.
Inspect slave cylinder for external leak (end boot will hold fluid). If nothing, a leaking MC is likely.
Old Dec 25, 2016 | 12:41 PM
h11keu's Avatar
many thanks ...kev
Airhead
Feb 18, 2016 11:03 AM
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
