clutch engagement
Old May 21, 2006 | 12:47 PM
416communter
Default clutch engagement
Hello all:
My clutch pedal engages closer to the floor after a hard acceleration. ie, revs above 4000, and at least 3/4 throttle, after two shifts like this, the clutch engages in the bottom 1/4 of its travel, as opposed to in the middle. Really annoying. After a couple of "easy" shifts, it goes away, and behaves normally.
I've thought of the automatic adjuster, and perhaps (although this seems a little out there) a bulge in the hydraulic hose that actuates the clutch.
Any ideas out there? Anybody else have this issue?
Thanks for any help.
Old May 21, 2006 | 05:37 PM
deserthonda's Avatar
Default RE: clutch engagement
how many miles on the car ?? if less than 36k ,, take it to the dealer it is under warranty
Old May 22, 2006 | 11:58 AM
416communter
Hi,
It's got 60k (km), and it's a 04 coupe, v6 manual, 6 speed. (that part was in the post at the bottom)
Old May 22, 2006 | 12:00 PM
416communter
I took it to the dealer, they said it felt "normal", but changed out the clutch fluid anyway. I don't think it's normal, and it's driving me nuts.
Old May 22, 2006 | 12:07 PM
416communter
sorry, deserthonda, I just realised that is your signature line. I thought you had missed MY signature line.
Old May 22, 2006 | 12:08 PM
ORIGINAL: 416communter
Hi,
hello 416...... I know your car is a 04.. it is on your signature i saw that.i wish all the members would do that... i was not asking for the year and model,, that is in my signature, it is always there to remind members to input year and model,,
unfortunatelly i cannot help you much from where i am sitting , this is a situation where i would have to drive and feel the clutch ,i was going to suggest that they would bleed the clutch system in case there was air in it , but they have already done that.
the only thing i can reccomend is, if you know anyone with similar car as yours to test drive it and see how the clutch feels , or if the dealer has a used car same as yours, tell them you thinking of buying it and take it on a test drive ..
in the mean time i will look up to see what i can find ( bulletin ) ...
Old May 22, 2006 | 12:15 PM
sorry no bulletins found on your issue, the only bulletins regarding 04 v6 mt are ..
, clutch pedal squeaks ,, and ..
hard to shift into first gear, reverse grinds
Old May 23, 2006 | 10:31 PM
416communter
thanks DH,
It's the strangest feeling, (I've driven sticks for 25 yrs) and never felt this. Peddle effort increases, and kind of hangs 75% of the way down. And the downshift comes on right away, and unexpectedly. I don't abuse the car, but it's like a horse and should be exercised, in my opinion. I didn't buy it so I could drive around like I had a corolla or something. I did see some stuff on braided clutch lines, presumably to eliminate any bulging, which I would expect to result in longer pedal travel since the fluid colum would change volume. As well the issue came up when the weather got a little warmer, which made me suspect the rubber hose. Anyway, thanks for your help, there aren't many of these things around that I can find, so I'll just keep after the dealer to fix it.
Thanks again.
Old Apr 24, 2014 | 12:15 PM
afajardo41's Avatar
I have this same EXACT issue. With an 06 Manual Accord v6. I haven't found anything that would help! Did you ever find out what was wrong/ how to fix it?
Originally Posted by 416communter
Hello all:
MGF 1996 Accord
Jul 13, 2015 11:48 AM
j894
Apr 18, 2013 05:59 PM
F23AccordLX
Jan 29, 2007 08:13 PM
MassAccord
Jul 24, 2006 01:11 AM
2.2ex965spd
Apr 20, 2006 03:28 PM
