clutch slipping
Old Oct 26, 2008 | 06:47 AM
steve57
Default clutch slipping
my accord clutch has been slipping for past 10000 miles could this be related to fluid running very low recently or is it definitely on way out
Old Oct 26, 2008 | 07:29 AM
Default RE: clutch slipping
Supply some details of vehicle.
Manual clutch shift, feel, and starting problems can be caused by bad slave or master cylinders. Look for leaks at both. Check inside vehicle for MC. OEM master cylinder is best to avoid having to adjust the booster push rod-master cylinder clearance.
Old Oct 26, 2008 | 12:44 PM
finch13's Avatar
Could it possibly be that the clutch is just worn out? What are we working with? Year/trim/engine/tranny/mileage in your sig per the forum rules, please.
Old Oct 27, 2008 | 07:08 AM
Generally, problems with the clutch hydraulic system will not cause the clutch to slip. Sorta the opposite problem, it wont disengage reliably. So it DOES sound like a worn-out clutch.
But come on, tell us what kind of car... Honda has been making Accords since about 1977 & theyre not all the same.
Old Oct 29, 2008 | 01:18 AM
deserthonda's Avatar
I agree with JIm..........if clutch slips than it is not a low fluid issue ,, most likely clutch is worn
daddy
Jun 15, 2010 03:23 AM
JimBlake
May 18, 2009 09:38 PM
honda285
Dec 29, 2008 02:46 PM
GRAY WHISKERS
Nov 2, 2008 02:35 PM
tamb
Jul 21, 2006 01:05 AM
