cold starting probs
Old Jul 20, 2013 | 08:26 PM
spsweet's Avatar
if I turn the key off and back on again it will run for another two sec and stop
Old Jul 21, 2013 | 07:30 AM
Can you check for codes in the ECU just to be sure there are not any.
Also, once you do get it started and running and to normal op temp - does the same thing happen if you shut the car off and try to re-start it.
Sorry for the extra questions - early and don't always have enough coffee yet
Old Jul 22, 2013 | 03:24 PM
spsweet's Avatar
once it is running and comes up to temp it will restart without a prob and I will try to check the codes this evening .... whitch two pins do I need to connct ?
Old Jul 28, 2013 | 08:52 PM
spsweet's Avatar
ok I pulled the codes on the car and they are 15, 3, 7
Old Jul 28, 2013 | 10:22 PM
If the check engine light flashed these codes, then...
code 3 = MAP sensor
code 7 = throttle position sensor
code 15 = ignition output signal (ignitor)
The problems can be the sensors or the wiring.
What are the wire colors going to the map sensor? And the wire colors going to the throttle position sensor?
If the D4 light flashed some of the codes, then let us know, because those are a different set of codes.
ahren111
Jan 28, 2011 12:11 PM
carb_67
Oct 22, 2009 12:59 AM
deanog21
Nov 26, 2008 11:54 AM
stevieb
Jul 9, 2007 02:33 PM
fire_walker_78
Aug 23, 2005 09:12 PM
