condenser fan draining battery
Old Dec 1, 2011 | 12:51 AM
scatdog65's Avatar
Post condenser fan draining battery
My 1996 accord ex 2.2L condenser fan is staying on and draining my battery. It just started doing it a couple of days ago. The most interesting thing about this problem is that the vehicles a/c does not even work or is even charged with freon. The fan just suddenly came on and stays on. I had to pull the condenser fan fuse to keep it from running. Has anybody come across this problem? Any thoughts as to what would cause this to happen? Any advice would be appreciated.Thanks
Old Dec 1, 2011 | 01:46 AM
Try another New condenser Fan Fuse and see if that old one is the culprit...
Old Dec 1, 2011 | 01:42 PM
How about a stuck-closed fan relay?
Old Dec 1, 2011 | 07:08 PM
x2......easy to check the relay, just behind the drivers headlight, behind the rad there are two relays "hanging" from a bracket....one is the cond fan relay, the other is the ac compr relay....if you need the wire colors let me know.
CDJDM07
Aug 24, 2011 09:51 AM
RJADM2000
Aug 3, 2009 09:49 AM
RTM1216
Apr 12, 2009 12:54 PM
driver6198
Jan 2, 2009 11:19 PM
BallaxB09
Dec 12, 2007 06:21 PM
