Continous O2 sensor problem
Old May 27, 2015 | 10:13 PM
Guldens's Avatar
Default Continous O2 sensor problem
I just bought my first Honda, a 1993, Accord, 4 cyl., automatic, with 300K miles. The guy I got it from explained it has an O2 sensor problem that none of the mechanics, he has taken it to, can solve. The check engine light comes on, the car starts to run rough for a short while and then smooth's out again. The code says it's a bad O2 sensor. The first time he replaced it with an after market one. The check engine light went out and the car ran fine again, but only for a couple of weeks. The same scenario occurred and this time he replaced it with an NGK sensor. The process started all over again. This time he replaced it with another recommended sensor. The check engine again came on after about a month. The light can come on anytime within 2 to 5 weeks. It usually happens just after he starts driving the car. The light comes on, it runs rough and then when it fully warms up, it runs fine again. Check engine light stays on until the sensor is replaced. Other than this problem, the car runs nice, shifts fine, no smoke out the tail pipe, good acceleration. Hopefully some one has had this problem and knows the answer.
Old May 28, 2015 | 06:25 AM
Turtlehead's Avatar
It could potentially be an intake leak, possibly the intake manifold gasket. With the car cold take a spray bottle, start the car and gently spray around the intake and listen/feel for a change in the way the engine runs. Otherwise Denso sensors are sold on the aftermarket and are the best as Denso makes Honda's.
Old May 28, 2015 | 06:59 AM
What code is set when light comes on?
pondrun
Nov 8, 2021 09:40 AM
dmost30
Sep 8, 2008 12:42 AM
dmost30
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
o4vroom
Dec 23, 2005 04:09 PM
