Sponsored by:
Sponsored by:
Cool Accord
Old 01-29-2011, 08:01 AM
Hera's Avatar
Default Cool Accord
As my recently acquired 96 Accord coupe takes ages to warm up I completely blanked off the radiator, with a view to removing the block in a few miles, when overheating threatened.
60 miles later the gauge is at its usual place well below mid point.
Methinks these cars are better suited to Dubai than Derbyshire ?
Old 01-29-2011, 08:26 AM
Could the t-stat be stuck partially open...this would cause it to not warm up. Has the t-stat been replaced? I'm assuming that when the gauge is low you are not getting hot air inside.
The gauge on my 95 reads at about 4 o'clock when warm. So not sure how that relates to "the gauge is at its usual place well below mid point".
Old 01-29-2011, 09:13 AM
It may be failed thermostat, someone removed the thermostat or replaced w/ poor quality. OEM thermostats are worth the slightly higher cost IMO.
Old 01-30-2011, 02:43 AM
Hera's Avatar
Dont know about the t stat : will investigate. The car becomes very warm eventually - gauge at 4.00/4.30 .
Old 01-30-2011, 09:18 AM
X2 on the thermostat.
With a stuck-open thermostat, the temperature will eventually get up there but it'll take extra long.
Old 01-30-2011, 09:31 AM
It is supposed to be below halfway, or at least the 2 I have owned have been.
4x4aholic
11-03-2013 06:26 AM
tkenwort99
05-29-2012 06:25 PM
zolcat
04-20-2012 06:36 PM
EXV6NIGHTHAWK
10-09-2010 10:35 PM
00Accord3
07-31-2009 11:15 AM
Quick Reply: Cool Accord
