Coolant is burning...somewhere
Old Jan 4, 2016 | 02:30 PM
Tirebiter's Avatar
Default Coolant is burning...somewhere
After addressing a parasitic amp draw, I then had steam coming from underneath the hood. The culprit seemed to be the upper radiator hose, because the end nearest the radiator was wet.
One radiator hose, two clamps and half a gallon of fresh coolant later, there is still steam coming from the engine compartment. Only the source isn't a leaky radiator hose.
The steam is coming from between the engine block and the exhaust manifold. And judging from the smell, it's obviously anti-freeze.
This isn't good, is it?
Old Jan 4, 2016 | 02:37 PM
shipo's Avatar
Make, model, options, and year of car?
Old Jan 4, 2016 | 02:49 PM
Dr. Drivability's Avatar
Head gasket, thermostat housing, other coolant hoses...like shipo said, year and engine would be helpful.
Old Jan 5, 2016 | 12:04 PM
Tirebiter's Avatar
It's a 1999 4 cylinder Accord LX coupe, automatic transmission.
Completely stock. No options.
Old Jan 5, 2016 | 09:42 PM
A sealed system should be able to hold 15-16 psi for a long time (look at radiator cap for max pressure). If the system isn't holding pressure, you definitely have a leak.
Some parts stores have a radiator pressure tester as a loaner tool. When the engine is cold, pressurize the radiator to the number on the radiator cap and try to locate the leak. It should be easier to find vs the steam you see now.
RobinsonRicer
Aug 31, 2012 06:48 AM
Cinci90
Jan 30, 2009 01:05 PM
tru3_k177
Jan 28, 2008 09:52 PM
mdd0127
May 21, 2007 09:27 PM
aang
May 25, 2005 07:25 PM
