Coolant leak Passenger side
Old Mar 9, 2012 | 11:55 AM
wrencredle's Avatar
Default Coolant leak Passenger side
I have a very bad coolant leak, that ends up dripping on the transmission. Both the radiator hoses are fine. So I was thinking this could be leaking somewhere from the thermostat to the block? Just wondering if anyone had any ideas on something else that can be leaking. It's very bad I have to add a gallon of antifreeze after a short drive.
Old Mar 9, 2012 | 03:04 PM
You can usually rent a radiator pressure tester from most parts stores. You want to find the source of the leak. The radiator should hold about 16 psi.
The leak can be from anywhere.
If your leak is as bad as you describe, the leak should be pretty obvious. Do this when the engine is cold and you should be able to find where coolant is dripping from.
Good luck.
Old Mar 10, 2012 | 12:17 AM
wrencredle's Avatar
Ah thx didnt need a tester to find it lol . it was the heater hose from the valve to the engine.
sbi
May 19, 2012 08:38 PM
v-tec23
Aug 14, 2010 08:43 AM
ispin69
Jul 16, 2010 09:58 PM
cengland84
Dec 25, 2008 11:18 AM
19accord92
Apr 10, 2006 03:52 PM
