coolant problem
Old Feb 19, 2007 | 12:26 AM
lm_dicp
Default coolant problem
My car is accord LX 98.
Today, I found the coolant tank was empty, and I filled it. But after I drived 20 minutes I found it was empty again, so I refilled it . Then I drive for another 30 minutes, It happened again. I dont konw what's the problem. Is there any possible leakage or just because radiator need more coolant. Hopefully, someone can help me. thanks!
Old Feb 19, 2007 | 12:54 AM
Ericsmiller88's Avatar
Default RE: coolant problem
Have you checked your oil, does it look like chocolate milkshake? [/align]Could be a bad head gasket.[/align]Also check the hoses could be coming out when it is under pressure. [/align]I would say clean the engine compartment so that all of the old coolant is gone, this way if there is a leak it is easier to spot.[/align]or you could always have a friend drive behind you to try and spot leaks?[:-][/align]
Old Feb 19, 2007 | 01:02 AM
lm_dicp
Thank your for your suggestion.
If I go to garage to take a look, how much I will be charged? (just check if it is leak)
Thanks
Old Feb 19, 2007 | 01:09 AM
psssh idk about that could be any price depending on the place you go
i have about 3-4 shops around here and each charge diff. some cheaper then others
i always hop from shop to shop though and take the cheapest guy
Old Feb 19, 2007 | 01:10 AM
deserthonda's Avatar
just have a shop or yourself pressure test the cooling system, if any leak it will show up
the charge to just pressure test system and let you know what is going on cannot be more than 30-50- dollars .. if they find a leak then ask them to give you a quote and let you know exactly what is leaking
let us know ..
Old Feb 19, 2007 | 01:38 AM
lm_dicp
Can I fill radiator and tank to look for leakage spot? Does this damage my car?
Thanks a lot.
Old Feb 19, 2007 | 02:17 AM
lm_dicp
I just check engineer oil, it looks like chocolate color. what is the problem?
Old Feb 19, 2007 | 03:40 AM
Crazyguy's Avatar
if its like milk chocolate then its time for a headgasket.
Old Feb 19, 2007 | 11:03 AM
go to a shop and have them chk out if the head gasket is blown,,,,,,,did engine overheat on you recently ??
Kyleholland
Jun 15, 2013 07:55 PM
ghostgxz
Jan 18, 2013 01:50 AM
beastyme
Oct 19, 2012 05:01 AM
AkbarGr8
Sep 8, 2010 06:28 PM
bgtcket5
Aug 9, 2007 05:48 PM
