Which coolant temp sensor sends to the gauge? 01 Honda Accord V6
Old Aug 27, 2015 | 11:33 AM
Rock Auto shows SMP NS158 cross references the Honda part numbers:28900-P7X-013 and 28900-P7X-003 for a V6.
Rock Auto shows SMP NS156 cross references the Honda part number 28900-P6H-013 for a 4 cylinder.
Edit: This other site show SMP NS156 as correct for your V6:
http://ecatalog.smpcorp.com/STD/#/vehicles
Old Aug 30, 2019 | 02:12 AM
Jacob Smiley Stone's Avatar
On a 2001, the temperature gauge gets its signal from the PCM. The PCM gets its input from the ECT sensor.
A 2001 does not have a gauge sending unit like the 98-99 Accords.
Same question? About the garage sending unit on 98 that I have. Snap-On scanner that I have says temp sensor voltage is at 257 F. And when you hit it with a laser temp gun it shows 198 Gage inside on dash shows half way up unplug it sensor and it still reads 257 degrees F.
Old Aug 30, 2019 | 09:05 AM
Is your 1998 a V-6 or 4-cyl?
On the 4-cyl, the sender for the temperature gauge is separate from the sensor for the PCM and also separate from the fan switches. I imagine it's similar for the V-6 but I'm not sure.
draker
Aug 24, 2025 07:16 PM
jlatessa
Jan 18, 2018 08:18 AM
mg170
Mar 12, 2015 10:47 PM
lecola
Jan 10, 2013 06:30 PM
heathzx
Sep 26, 2012 09:47 AM
