Cooling fans not working
Old Jan 5, 2008 | 03:03 PM
SteveZ's Avatar
Default RE: Cooling fans not working
I thought it should a least get warm. It's not even getting warm and the fan doesn't come on . I hope it's the thermostat.
Old Jan 5, 2008 | 04:59 PM
HondatechAV6's Avatar
the upper hose gets hot first, then as the coolant circulates in the block it warms up the thermostat which opens and allows hot coolant to flow through the radiator. the upper and lower hoses will be pretty much the same temperature at idle.
Old Jan 5, 2008 | 05:04 PM
SteveZ's Avatar
So do you think a new thermostat will be the fix? Thanks !
Old Jan 5, 2008 | 05:08 PM
well, assuming your cooling system isn't clogged up with junk yeah, it should at least fix the problem with the lower radiator hose not warming up.
phatboyslim2012
Feb 19, 2012 07:23 PM
pab59y
Sep 13, 2011 06:33 PM
Golddoor
Aug 17, 2011 05:10 PM
oregonaccord
Jul 22, 2011 09:07 AM
stephenml
Nov 2, 2009 09:55 AM
