Couple of Issues
Old Jun 17, 2006 | 05:11 AM
chrisc
Default Couple of Issues
Wonder if anyone can help - I have an Accord 6 speed 2.4 Exec (2003) - just bought it 6 months ago. Delighted with the car but I have noticed a few things which I would really appreciate some advice on.
1. Seems to be quite a large water leak under the car (was told this could be air conditioning)
2. Suspicious that the car has lost a fair bit of power since I bought it.
3. When changing gear there is often a "whine" or "squeak" - almost like the clutch slipping...
I am not technical at all on cars but been a bit suspicious since I bought it since the car has a tow bar and I have been concerned that the previous owner was dragging about his house on the back of the car.
Since it is in warranty I would like to get these things checked out - but I have no idea / information to be armed with when approaching the dealer.
Really appreciate any help - thanks
Chris
Old Jun 17, 2006 | 10:40 AM
YeuEmMaiMai's Avatar
Default RE: Couple of Issues
1. If the water is clear, then don't worry as it is condensate from the A/C. All air conditioners will remove moisture from the air as they operate
2. Do you notice any chk engine lights or other abnormalities?
3. Have the dealer inspect the clutch and see what they find
Old Jun 18, 2006 | 04:24 PM
chrisc
Thanks for your response. Will see what they say re the clutch? Is it normal to expect to notice and significant degredation of power with a car at this stage -ie 3 years and 35000 miles? No engine warning lights as - the only thing that makes me suspicious was the car had a tow bar and I guess towing around caravan's / boats etc could place extra strain on the car.
Thanks again for your help as any pointers or thoughts would be most appreciated.
Old Jun 18, 2006 | 04:58 PM
if your clutch is starting to slip, it would appear that car has lost some power. The lowing limit of an accord is 1000lbs (us cars) I would not be too worried about that unless the rear end is sagging.
Rollingskies
Oct 29, 2012 05:28 PM
phastlt1
Feb 13, 2011 12:12 PM
Dan333sp
Aug 16, 2010 06:49 PM
RadRacer513
Jul 22, 2010 12:03 PM
squeege
Jul 12, 2010 11:02 PM
