Cranks All Day But Not Turning Over.... No Spark Please Help!
Old May 9, 2012 | 11:06 PM
Originally Posted by BLAZN420
Well after the rev limiter starting acting weird I took it straight back to the mechanic and left it overnight. They connected 3 different High End scanners and kept getting the same code. ''TPS Sensor Malfunction" The TPS sensor is inside the dizzy and that's the only thing I didn't change.
The code is TPS SENSOR
Anybody have any feedback or ideas???
Thanks
What was the actual trouble code number?
TPS is not in the dizzy. IIRC, it's on the throttle body for your car.
Old May 9, 2012 | 11:12 PM
Dr. Drivability's Avatar
Well, if it's the TPS sensor that's bad you used to have to replace the whole throttle body, but now I think they do make an aftermarket kit to replace it. based on your symptoms now and what you've replaced already, it's either that or the ecm.
Old May 10, 2012 | 02:58 AM
Check to see if the connector for the TPS got mixed up with the MAP sensor connector.
Old May 10, 2012 | 12:37 PM
BLAZN420's Avatar
Default Thanks
When we did the swap I asked my mechanic to give me the extra parts from the JDM Engine. He gave me the Alternator, Power Steering Pump, Belts, Timing Cover, And the complete Throttle Body with both the MAP Sensor and the TPS sensor with the hex screws on it on it. I Already swapped out the MAP sensor just to see if that would help and of course only took 5 mins. It didn't help anything.
I'm thinking about swapping out the whole throttle body with the spare JDM one Instead of just swapping the TPS sensor.
Can I do that?
Will it be a problem?
Should I just swap the TPS Sensor?
How hard is it to swap the throttle body?
Old Aug 10, 2012 | 08:26 PM
lovebug92's Avatar
i have the same car except dx and its having the same exact problem did you ever figure out what was wrong.
Old Aug 10, 2012 | 08:46 PM
lovebug, start a new thread, so this one is not so confusing. Let us know what you have done so far on your car to repair the problem.
Old Aug 11, 2012 | 06:11 PM
  #17
BLAZN420's Avatar
It was a combo of 2 seperate problems. It was my Crank Sensor and My Dizzy.
I bought a used junkyard crank sensor the first time..... I should have listened to my mechanic and got a new one...
Also dont buy a cheap $60.00 dolllar chinese ebay Crank Sensor, Its a waste of money and time.
Its alot of labor to change these things so get it right the first time
I ended up buying a " Beck Arnley" Crank Sensor from Rock Auto for about $150.00. Much better then $270.00 for an OEM. My mechanic told me it was a high quality brand.
I found a Complete Dizzy from a salvage yard on Ebay for $55.00. It was in great shape. I checked out the pics first. I just changed the outer O ring with the new one from my old Dizzy and changed the rotor.
Anyways after a huge headache my baby has been back on the road for about 3,000 miles now and running like a champ!
In the end it was a combo of my Crank Sensor and my Dizzy
Good Luck I hope this helps
Old Aug 12, 2012 | 07:20 AM
  #18
Thanks for coming back with the end result
thehondaguy
Apr 21, 2013 09:19 AM
mack89
Apr 11, 2013 11:27 AM
jbchdclark
Aug 31, 2012 08:14 PM
huhdo
Aug 30, 2012 09:06 PM
fastdart360
Jan 25, 2008 09:19 AM
